Chime unit problem
Old 08-23-05, 11:20 AM
chson
Chime unit problem
Everytime I attach the transformer and button wires to my new chime unit, it rings once and then emits a buzzing sound until the wires are disconnected. I've tested the actual button and transformer and they work fine. Has anybody experienced anything like this before?
Old 08-23-05, 12:47 PM
G
Received 2 Votes on 2 Posts
You either have two bare wires touching or a stuck pushbutton. The transformer is working and so is the chime. The problem is that the chime is staying on (buzzing).
First check your wiring at the switch. disconnect one wire at the switch, turn on the power - the chime should be silent. If it is buzzing, you have a wiring short. If it is quiet, briefly touch the disconnected pushbutton wire to the other push button wire. If the chime dings when the wires are together and dongs when they are separated, the problem is in the pushbutton.
Also be sure that you have one transformer wire going to the chime and the other going to the switch. The other wire from the swtch attaches to the F or front door terminal on the chime.
Old 08-23-05, 12:53 PM
chson
Hi goldstar, thanks for replying! I'm going to look at the switch again today.
Old 08-24-05, 07:07 PM
C
You might have the components in parallel also. They should be in series.
