12 guage or 14??
Old 08-23-05, 05:04 PM
GirlDIYer
12 guage or 14??
I want to convert a 110v outlet to a 220v outlet, How do I know if the wire is 12 or 14 guage?
Old 08-23-05, 05:36 PM
Look on the jacket.
Compare it to another piece of wire of known size.
Just use the same amp breaker that was there and you should be OK.
15 amp = #14
20 amp = #12
Old 08-23-05, 05:45 PM
Comparing the wire in question to a piece of known wire or using a wire gauge would be your best bet. If you can only see the wiring from the receptacle box or the panel box you may not be able to read the gauge off of the jacket.
I would be wary of using the breaker size to determine wire size, especially in an older house.
Old 08-23-05, 05:58 PM
GirlDIYer
I may consider leaving this one to a pro. lol I think I will do the majority of the project and call in an electrician for this part. Thanks for your help.
