Buss bar discoloration
Old 08-30-05, 10:45 PM
bmartinez
Unhappy Buss bar discoloration
I am selling my home and the inspector found discoloration on the buss bar can anyone tell me why this would happen and if it needs to be replaced
Old 08-31-05, 05:58 AM
I am guessing that this is a Pushmatic panel? You probably have or have had a loose connection and it heated up. When the metal heats up it will discolor.
Make sure all connections are tight. If it is a pushmatic panel then be carefull not to let the screwdriver slip. Those panels have been known to claim many screwdrivers.
You should be OK after this.
Old 08-31-05, 09:00 AM
It depends on the severity of the heat damage to the buss bar. If this is an issue with the buyers, I highly recommend you have the panel inspected by a licenced electrician. Home inspectors are great for pointing out potential problems, but they often lack the expertise to deal with a specific issue. This is especially true when it comes to electrical.
