Changing 220 to 110
Old 09-01-05, 02:29 PM
werff
Changing 220 to 110
Hello everyone. I have a home built in 1968 that has the original cooktop and double wall oven. I want to change it out with gas and 110. What is the best way to convert the 220 to 110? thank you very much
Old 09-01-05, 03:04 PM
The problem with converting is that the old electrical wiring may not have a grounding wire or conduit. So you first need to check to see if the existing wiring is in metallic conduit all the way from the panel (to provide grounding), or if there is a bare or green wire coming to the location to provide the grounding. If the answer is no to all, then you need to run a new circuit. If you do have grounding, post back for more information.
Old 09-01-05, 03:08 PM
Please describe the wires you have available at the existing 220 receptacle, and someone will be able to advise you further. Also, please indicate if the existing wire is copper or aluminum and if you have a fuse box or breaker panel.
