crack Fridge
Old 09-01-05, 05:09 PM
samkchan
crack Fridge
I have a can that drop and cracked the liner of the fridge. How do I repair it? Or is it repairable? thanks
Here is a picture of where the crack is. It's about 1.5-2 inches.
Crack
Old 09-01-05, 06:47 PM
I would think that any good caulk could be applied. When it sets up it will be sightly flexible to handle expansion and contraction, will seal the fridge from losing cold or having possible spills leak through, and if carefully troweled, will be almost invisible. Fridge looks white so thats the color I would go with.
Old 09-01-05, 07:01 PM
samkchan
Thanks
Would caulk be able to handle the tempeture? I also read to use some white multipurpose sealant. Is it the same as caulk.
Some guy also suggest proxy that use to glue fiberglass. Would this work?
Thanks
Old 09-01-05, 07:07 PM
Why don't you try this question in the appliance forum. You may get other suggestions.
Old 09-02-05, 09:28 AM
Exterior grade caulk can handle temps well below zero. Your fridge probably does not get below about 35 degrees in the lower section.
