Butt Splice For Joining Two Lengths Of Wire ?
Old 09-04-05, 07:21 AM
Hello:,
--Might be a duplicate post ? PC acting up again--
Was in Home Depot the other day and saw what I guess can be termed a package of "Butt-Splices." They are insulated. Would be used for joining, e.g., 2 pieces of stripped No. 14 (in line) to each other. Would take the place of a wire nut, apparently.
Was wondering about how one squeezes down on them.
Is there a dedicated tool for doing this?
I would imagine so, as if I use a small needle nose, or a small vice grip, I would think that the insulation would become damaged.
How does one actually use them ?
Thanks,
Bob
Old 09-04-05, 08:23 AM
Are these crimp fittings? If so, you need a real crimping too, and such tools are far too expensive to be practical for infrequent usage. I suggest you look for some other connector.
Old 09-04-05, 08:25 AM
The tool would be called a crimper
This picture is a stripper/crimper combination, the end towards the handle is the end you would use to crimp the "butt splices". picture
Here is another picture of a crimper with a slight description. picture2
They vary in many brands and you can get a crimper by itself for around 5 bucks, I couldn't find any on homedepot.com
Just one question for you, this 14 wire you want to splice is it stranded or solid wire?
Old 09-04-05, 12:32 PM
From OP
Hi,
Thanks for help.
Thinking of using it on solid, No. 14.
Bob
Old 09-04-05, 02:02 PM
Then I would find another connection means as John suggested, solid wire and butt connectors don't mix very well at all.
Is wire nuts not an option?
