Just replaced element, now no hot water.
I just replaced the lower element on my water heater, and now I get no hot water at all. It's not the breaker, and it is getting plenty of cold water in the tank. Any ideas? The heater was making hot water before I changed the element.
Did you reset the termostat after you replace the element? Unless you wired it incorrectly then that may be your problem.
Last edited by jbfan; 09-08-05 at 08:14 PM. Reason: Changed word that looked incorrect (aired to wired)
