Low voltage lines
Old 09-09-05, 07:49 PM
Low voltage lines
Is it permissible (code wise) to run low voltage lines (landscape lights) in the same conduit with satellite tv cable? The distance is approxiamately 8 feet.
Thanks
Leslie
Old 09-09-05, 08:22 PM
Do not do this. You want your TV signal to be as clear as possible. When you run any other signal near the TV lines you run the risk of interference.
Old 09-09-05, 08:38 PM
It is permissible, but as Bob said, not advisable.
