Plug on coffee maker
Old 09-11-05, 02:42 AM
twilly
A coffee making machine bought in Germany and brought back to UK as a gift.
It has a 2 pin plug can it be converted safely in some way to work on UK system.
Thanks.
Old 09-11-05, 09:01 AM
What voltage do they run in Germany, and what voltage do you run in the UK?
Old 09-11-05, 11:19 AM
twilly
240volts in UK not sure about Germany, Thanks anyway
Old 09-11-05, 12:08 PM
nominally 220-230 volts, 50 Hz in Germany.
Old 09-11-05, 08:57 PM
The EU harmonizes voltage is 230V +10% -6%, 50 Hz, that includes the UK and Germany. The appliance will work fine.
You can get adapters to convert one to the other, but get a good one that will take the power the coffe maker will draw, and has a 13A fuse.
Or get an electrician to make one with a trailing Shucko socket attached to a BS1363 plug.
Old 09-16-05, 02:20 PM
twilly
Thanks everyone for your replies, i wondered if there was an adapter that could be used as i've only seen 2 pin to 3 or shaver plugs which are unsuitable as they're just 1 amp. Its clear from your replies that you can get them so i'll keep looking.
Thanks again.
