Height of outlets and switches in garage
Old 09-11-05, 12:30 PM
RDele
In NJ
What are the locations of the outlets and switches to be above the floor in a garage application?
Thanks
Old 09-11-05, 12:54 PM
No real "height".... I've found that a lot of electricians will place their outlet boxes a "hammer handle" above the floor - and that's what I use....
Wall switches should be convenient.... 46inches is about right.... though you can go higher or lower.
Then again... I don't live in NJ
Old 09-11-05, 06:29 PM
Received 318 Votes on 292 Posts
In the house I like to have outlets a "hammers length" up. In the garage I like to have them about 4' up. You don't have to bend over to get to the outlet and they don't get covered by stuff pilet up on the floor.
Old 09-11-05, 07:05 PM
As has been stated, there is no code requirement for the height.
Many recommend just above four feet for the garage, so that they are visible above a piece of plywood leaning against the wall.
Old 09-11-05, 07:19 PM
ampz's Avatar
When I 1st started I worked for a N.J. electrician & he always had to go to the inspectors of each township for their requirements. He was even almost cited by one inspector for not having his Co. name & license # on his truck.If I were you I would check with the inspector
Old 09-12-05, 09:28 AM
If you work with any sheet goods (plywood etc.) I would put the outlets at 54"...otherwise when you lean that 4x8 sheet against the wall you will cover your outlets...
hth
Doug
Old 09-12-05, 10:30 AM
Received 42 Votes on 40 Posts
Some areas enforce a minimum height of receptacles of at least 24" above the floor to be above accumulated flammable vapors that could be present in a garage. I however agree with the other posters that somewhere around 4 feet is a good height.
