Missing Something
Old 09-12-05, 10:31 AM
Missing Something
I know amperage can be found by dividing wattage by volts but does the equation hold true for a water heater. When I divide 11000 (2 x 5500) by 240 I get almost 46 amps but I know for a fact it is on 10/2 wire and a 30 amp breaker. Am I missing something here?
Thanks
Leslie
Old 09-12-05, 10:34 AM
In a typical residential electric water heater only one element is charged at a time.
Old 09-12-05, 10:36 AM
Thanks for the quick response. Didn't have a clue that they weren't both energized at the same time but it does make the equation work.
Thanks again
Old 09-12-05, 10:52 AM
The top element gets first priority. It runs until its thermostat is happy with the water temperature at the midpoint of the tank. Only then does the top thermostat shut off power to the top element, and allow power to be passed down to the lower thermostat, which will pass power to the lower element if necessary. This shortens the recovery time for the top part of the tank, allowing you to get at least some hot water more quickly after a large usage.
