Wiring double gang box
Old 09-17-05, 07:34 PM
Gizzorge's Avatar
Question Wiring double gang box
Hey all,
Just a quick question. I am adding new outlets in my garage and am using a double gang box so I have four outlets.
From the GFCI, do I need to run the wire (12/2) back out of the box and down into the other side, or can I just run the wire inside the box from the load part of the GFCI to the other outlet? I was just going to keep it all inside, but I just wanted to make sure!
Thanks!
Old 09-17-05, 07:45 PM
Yes, all the wire can be kept inside the box. Inside the box you don;t need to use cable either, you can use short pieces of wire (short as in six to eight inches) cut from cable.
Old 09-17-05, 07:47 PM
Gizzorge's Avatar
Nice... that's news to my ears! THanks!
