Breakers
Old 09-23-05, 08:43 AM
carson2
Breakers
Does if make a difference were or in what order you place breakers in your service box?
For instance, 30 amps on top and 20 or 15 amps on the bottom.
Old 09-23-05, 08:57 AM
Received 42 Votes on 40 Posts
The order does not matter at all.
Old 09-23-05, 03:18 PM
Received 115 Votes on 105 Posts
It makes no difference. You also can't save any money by balancing the load across the legs although it is a good idea to keep it as even as possible. The meter reads the power no matter which leg you use it from.
