Need simpler thermostat to run 2 fans
Old 09-25-05, 02:10 PM
Davejb's Avatar
Need simple thermostat to run 2 fans
Looked around on the web, couldn't find what I need.
I need a 110v thermostat, direct wire, that mounts in a single or square box. It will need to power on 2 very small fans at around 45 degrees and turn them off at 55 degrees, just a simple rotary temp selection knob would be fine. Didn't think it would be too hard to find but I guess I can't find the right place to look.
Old 09-25-05, 02:41 PM
Most "simple" mechanical thermostats probably have easily +/- 5 slop on the setpoints, so for you application you need something using RTD's and digital circuits. Available, and not necessarily expensive. Do more google.
Old 09-25-05, 03:08 PM
Ed Imeduc's Avatar
Wink
Get a Honeywell relay set up 110Vto 24V then use any digital tstat.
ED
Old 09-25-05, 04:33 PM
Davejb's Avatar
Been Googling some more, wouldn't something like this work?
http://www.iaqsource.com/index.php?m...=0&prod_id=576
It's a line voltage thermostat for baseboard heaters.
Old 09-25-05, 06:28 PM
Depends on what your application is. If you just need it to turn on somewhere between 40 and 50, and turn off several degrees higher, this might be ok.
Old 09-25-05, 09:52 PM
Ed Imeduc's Avatar
Wink
you said 45o to 55o. That stops at 50o. Most tstat like that dont keep temp's to close.
ED
Old 09-26-05, 06:42 PM
At the top of this Forum, locate "Useful Electrical Sites", and locate the "Honeywell 'On-Line' catalog "
At the W-S select, select "product search" which is listed under" products."
"Scroll" the bar indentified as "Select the Product Family" to arrive at "Temperature Controllers", and then select that listing.
You will find numerous design choices for specfic applications and specfic types of control circuits, and also a choice of appox 50 different temperature ranges.
