Digital Fan Timer wires
Old 09-27-05, 06:03 PM
I was installing a digital fan timer for my master bath room. I turned off power to the switch and noticed there was 3 wires a black a white and a blue. Where do I hook the blue wire too? There is only a white and black wire from the old rocker switch?
Old 09-27-05, 06:22 PM
This switch cannot be installed in this box. You bought a switch that requires a neutral and want to install it in a box without a neutral. There are switches that don't require a neutral. Most of them will run on a battery. Or you can buy a simple mechanical "turn past" switch.
