Mix 12-2 & 14-3 Wiring
Old 09-28-05, 07:49 AM
silverfox1208
Cool Mix 12-2 & 14-3 Wiring
Can I use 12-2 for feed to S1 and then use 14-3 to light and then to S2 on 3 Way Switch for 4 or 5 lights on the same switch. Will use 15 amp breaker.
Is there any advantage to using 12-2 as feed and then 14-3 to switches & lights ?
Also can I use a single 14-2 feed on 15 amp breaker to supply 10 lamps (75 watt each), 5 lamps on one 3 Way and 5 on another 3 Way, instead of running 2 (14-2) feeds ?
Thanks for your help !!!!
silverfox1208
Old 09-28-05, 08:11 AM
Technically, this is OK. I see no advantage to using the 12; 14 gauge is more than adequate for 5 lamps ( maybe 500 watts, less than 5 amps.)
The problem with mixing gauges is that there is the potential for someone in the future to see the 12 gauge and for some reason increase to a 20 amp breaker, not knowing that there is 14 in the circuit.
Old 09-28-05, 08:29 AM
Why are you stating 12-3 and 14-3? The "-3" in this case means three current carrying conductors plus one ground. Do you really mean 12-2 and 14-2, which would be two current carrying conductors and one ground.
Stay with one wire size. It eliminates confusion in the future.
Old 09-28-05, 08:40 AM
silverfox1208
Sorry, the feed is 12-2. Will use 14-3 for the 3 Way switches ? Thanks for the reply !!!!!
Old 09-28-05, 10:03 AM
Received 49 Votes on 46 Posts
I know first hand the confusion mentioned above. I was working in the crawlspace in my in-laws lake home and needed electricity in a spot where there was no outlet, but a piece of yellow 12-2 ran right through there with pleny of slack. I went and got a 20 amp outlet and was all set to go, except I couldn't find the breaker to turn of the juice in that wire. After I had turned off all of the 20 amp breakers, I started on the 15s. Sure enough, that's what it was. Would have saved lots of time and many trips in and out of the crawlspace if the electrician had used 14 ga. wire.
Old 09-28-05, 12:08 PM
d2frette
Wouldn't it be more sound to use 12-3 since the feed is 12 ga?
