Grounding Switches
Old 10-04-05, 04:18 PM
Grounding Switches
I added another switch (recessed light) to a box that already had two switches in it (I got a box for 3 switches). All the switches have no ground screw on them. All ground wires are just bunched together with a twist cap. I assume this is proper. I ask the question because I have seen some switches that have ground screws on them.
Old 10-04-05, 05:45 PM
Received 96 Votes on 88 Posts
If the switch has no ground screw the nyou are ok.
Old 10-05-05, 08:52 AM
Thanks for the reply.
Old 10-05-05, 09:01 AM
We have a new house. None of the switches have ground wire connected to the switch even though there is a grounding screw on the switch.
Is this OK?
Old 10-05-05, 09:37 AM
Is this OK?
Is a grounding wire present in the switch boxes? Are the branch circuit conductors enclosed in a continuous metallic raceway (used for grounding purposes)? If the answer is yes to any one of the questions then you need to ground the switches.
