new service
Old 10-07-05, 05:07 AM
New Member
new service
I'm Building a Metal storage shed/work shop and plan to install I 150 am service from the pole....The pole is approx 40 ft from the shed...I want to install service entrance cable in pvc....Can you connect pvc up to the meter?...How far under ground should the pvc be? 18 inches?.....What size shoud the cable be running 40 ft or so?......do I need 2 ground rod 6 ft apart?....Thanks...Any other info would be appreciated....
Old 10-07-05, 05:20 AM
Hire a professional to come up with plans for you. Working with the meter is no job for first timers. You may be able to do some of the work yourself, but you really need the help of a professional here. there's an awful lot involved with service drops.
