Running power to a well pump
Old 10-08-05, 11:03 AM
waelwell
Just bought a property. Very small "shack" that is basicly unlivable on the front of the property. There is a well for water about 100' away from the shack and power for the well comes from the shack.
Well, the shack is going away and a new house is going on the back of the property. The well will be about 175 feet from the new house. I need to run power from the temp power pole out to the well. What's the right way to do this? Oh, and it's a long story but the pipe to carry the water to the new home site is already in the ground.
- I assume I'm going to have to rent some sort of trench digger to put the cable in the ground.
- What type of cable do I have to use and given the length of the run, what guage?
- Do I have to run the cable inside any sort of pipe?
Thanks for all the help, believe me it's appreciated.
Bill
Old 10-08-05, 04:26 PM
You'll need to provide pump specs to determine the cable size. Provide amps and recommended breaker size.
Old 10-08-05, 07:58 PM
waelwell
Gosh... why didn't I realize you would need that info. The data are as follows:
230V
8 amps
20 amp breaker (why not a 15???)
#14 wire up to 300'
So I guess I have my wire size question answered. Oh, and now that I think of it, the distance to the well as well as the depth of the well (pump is at the bottom) need to be added to properly size the wire. I wasn't thinking of the well depth.
Now how should I run that cable underground?
Old 10-09-05, 07:12 AM
I'll wait other more expert to give an answer but I would not go less than #12 over that distance.
Yes I would bury it.
Old 10-09-05, 07:24 AM
"The data are as follows:"
One hardly ever sees the word "data" correctly followed by "are". You've made my day!
