throwing breaker
Old 10-11-05, 09:19 AM
siggia
throwing breaker
i disconnected an existing row of wall lights from a switch. i ran the switch to a newly installed set(4) of ceiling cans. when i turned the breaker that operated this switch back on i throw its breaker as well as another breaker. when i disconnect the new lights from the switch and turn the breaker back on i am still throwing the switch breaker and the unrelated breaker.
Why would i still be throwing the unrelated breaker?
any thoughts would be appreciated
Old 10-11-05, 09:25 AM
You have a short somewhere. Check the wiring. It also sounds like you somehow combined two circuits.
Old 10-11-05, 09:27 AM
Was there a white wire connected to the switch? I believe you might have tapped a switch loop.
Did you change any wiring at any existing light fixtures?
Are there any red wires in any of the boxes you're dealing with?
Old 10-11-05, 09:35 AM
siggia
if i did have a short in the other set of lights would they work when this switch is not on?
there is only the standard black and white wire in the switch.
behind the first light in the wall set it was wired three ways. to the light switch , to the first light and to a junction box that seems to continues to other outlets.
there are no red wires. one wire coming in has purple tape on it.
Old 10-11-05, 09:38 AM
I agree with John, you tapped a switch loop. This is something you cannot do. Put the wiring back the way it was and find another power source.
Old 10-11-05, 09:44 AM
siggia
are you saying that at end of the last wall light in continues on to something else?
because all i am looking to do is take the existing power supply to arow of lights disconnect it and run a different set of lights off it.
Old 10-11-05, 10:34 AM
where are you trying to grab the power from, and what wires are present at that location?
