Disconnect for 220V Line
Old 10-12-05, 08:48 AM
Lholt70
If I run a 220v 30a line out to my attached garage from my main panel in the basement, do I need to install a disconnect box in the garage next to the receptacle?
Old 10-12-05, 08:53 AM
R
Not if you are installing a receptacle. However, you may WANT one.
Old 10-12-05, 08:57 AM
Lholt70
Thank you. Is it only code to have a disconnect when you are running 220 out to a detached structure (garage) from the main structure's panel?
Old 10-12-05, 09:00 AM
T
What type of equipment is the 30 amp receptacle going to supply?
Old 10-12-05, 09:06 AM
R
Detached structures are a different ball game completely. If you are running 240 out to a detached structure, it is most likely to a circuit breaker panel (a sub panel). In this case the shut off is usually in the sub panel.
Old 10-13-05, 04:29 AM
Lholt70
Sorry for the delay. The situation is that a friend had a person install the line in his attached garage in case he wanted to purchase a 2 stage air compressor in the future. I knew that you needed a disconnect in a dettached stucture ( if you don't have a subpanel), but I wasn't sure if that was the case for an attached garage since the shut off (breaker) is in the main panel which is part of the overall structure. This line, most likely, will not be used for quite some time, so if it is not code, I won't worry about installing a shut off until he has a need for the line.
Old 10-13-05, 08:57 AM
I
When you do eventually install the compressor, you will need a disconnect but a cord-and-plug counts as a disconnect. Hard-wired motors, such as your air compressor need a disconnect in line of sight so that power cannot be accidentally turned on while someone is servicing the motor.
Old 10-14-05, 06:31 AM
Lholt70
I appreciate everybody's help. Thank you very much.
