tying lighting to electricity from irrigation valves
Old 10-12-05, 07:55 PM
raymond13
Red face tying lighting to electricity from irrigation valves
I want to install lighting but there is no place to tie in for electricity. There are irrigation valves that run off a time clock in the area and I was wondering if I can tie into the wires that run the valves to install lighting.
thank you for your help
Old 10-13-05, 01:14 AM
Not a good idea.
Most-most valves are 12 or 24 volts.
Old 10-13-05, 07:08 AM
Not only is the voltage a problem, but the power is a problem too. The transformer in the sprinkler controller isn't prepared to supply enough power for lighting.
