Feed Single pole switch from 3-way
Old 10-14-05, 12:48 PM
Ron C
I have 12-2 coming into my bath on a 20 amp circuit. I have power coming into a 3-way switch then 12-3 running from the switch to light to switch. Can I tap into the 3-way switch at the end of the run and add a receptacle that will always be on?
Thanks in advance
Old 10-14-05, 12:59 PM
R
No, not without replacing the wire from the light to the second switch. The second switch has no neutral wire.
Old 10-14-05, 01:38 PM
Received 326 Votes on 281 Posts
You can't even do with a new cable from the light. You need to go all the way back to the first switch where the power comes in.
Old 10-14-05, 01:58 PM
R
Thanks for the correction Joe. My mind must have been on the fritz.
