track lighting.
Old 10-15-05, 02:49 PM
track lighting.
I'm back!!! Everything is great in the basement. One last thing to do. Switch out the fixtures. Can you replace a regular fixture with track lighting??? What are the variables, and is it the same way that you connect any other fixture. Thanks.
Old 10-15-05, 08:18 PM
pcboss's Avatar
You will need to decide if you need and end feed or a middle of the run feed for the track.
The connections fro the track should be identified on the track by the color of the screws. White wire to silver screw, black to brass, ground to green or hex shaped.
Old 10-16-05, 03:03 AM
thanks,
if that is pretty much all, then cool.
