Welder Wiring
Old 10-17-05, 04:04 PM
a24ktlif
Welder Wiring
I recently bought an old Wards Power Kraft welder and am looking for some advise on installing the outlet. It is a 225 amp ac arc welder with an input of 50amp, 230 volts,60cycle single phase.. What size breaker will I use and What guage wire is needed? thank you
Old 10-17-05, 04:49 PM
What type of plug is on the end of the cord? Match the circuit tothe plug. Find your plug on the chart at this page.
http://www.powercabling.com/nema.htm
Old 10-18-05, 07:28 AM
a24ktlif
The cord has what looks like a dryer cord on the end like this
\ / ( this is not posting right , the top prong is centered )
I could not find this one on the site. I have the outlet matching the cord. Someone said 8 and one said 10 guage wire from the box to the outlet. Also does the "input of 50 amp" mean that i need a 50amp breaker in the breaker box.
Old 10-18-05, 08:41 AM
C
That is a 10-50 plug, the same as previously used on ranges.
You need to get a receptical to match, use #6 wire, on a 50A two pole breaker.
Old 10-19-05, 10:44 AM
a24ktlif
6 Guage wire and a 50 amp breaker .... Thanks :-)
