Relocating 220 outlet
Old 10-19-05, 07:04 AM
dsb2a
I am relocating my dryer from the basement to the upstairs. It is 3 prong 220. Would it be best to run a new line from the fuse box (twist in type) or could I splice into the existing line? Thanks for the help.
Old 10-19-05, 07:26 AM
R
You need to run a new FOUR wire line for the dryer. Three wire lines are no longer permitted, meaning that you cannot extend this circuit.
Old 10-19-05, 10:13 AM
P
If the cable to the existing out-let box is "10/3" Non-metallic cable with 3 insulated conductors and a bare Grounding-condutor, or "10/3" Armored cable which is 3 insulated conductors enclosed in a metallic jacket, you can extend the circuit and connect the required 4-slot receptacle.
Good Luck and Learn & Enjoy from the Experience!!!!!!!!
Old 10-19-05, 10:36 AM
dsb2a
Thanks for the info guys.
