Dead Receptacles
Old 10-23-05, 01:10 PM
Xroadwarrior2
Dead Receptacles
I have three dead receptacleson one wall and the range hood has quit working also. I've replaced all three as well as the breakers and they are still dead. Any help?
Old 10-23-05, 01:27 PM
Are these the only things on the circuit? Have you tested for power with a plug in type tester or any tester?
If there are other items on the circuit then check those locations as well. You may have a an open connection at a working location on the circuit.
Have you considered that a GFCI may be involved?
Old 10-23-05, 01:35 PM
Xroadwarrior2
Dead Receptacles
There was an attic fan wired in years ago but has never been used. They wired it in the attic. Wondering if wires there are loose as the range hood was last thing wired in cicuit about 20 years ago.
Old 10-23-05, 01:42 PM
You need to figure out where you have power and where you don't. Check each location on the circuit. Remake all connections as you go along. Use a two wire tester and check for power at each location.
