wiring a carrier air handler
Old 11-04-05, 06:04 AM
I am wiring a 5 ton carrier air handler. It has 2 60 amp breakers. They are marked 10 k on the handles. Is it necessary to run 2 sets of 6-2 wire from the main service or is there some kit available for this?
Old 11-04-05, 07:22 AM
There is no "kit"; the issue is a Code-approved Wiring Method for routing the conductors between the two connection-points.
The simplest and most economical ( cheapest?) , depending upon stuctural conditons ,would be Type NM ( Non-metallic) cable.
Routing the W-M across and under finished walls & ceilings may require PVC Conduit.
Old 11-04-05, 08:10 AM
Stevetra's Avatar
When you say 2 60amp breakers, do you mean 2-220 breakers taking up a total of 4 slots, or 1- 220 breaker, taking up 2 slots?
Is the air handler inside...if so...where?
