nEW CIRCUIT
Old 11-04-05, 09:25 AM
T
New Member
nEW CIRCUIT
I'm running a circuit from my main panel to my shed about 130 ft away ...I ran 10 gauge wire from a pull box in my basement to a box in the shed...my question is con I run 12 gauge from my panel to the pull box and splice the 10 and 12 together or do i need to run 10 from the panel to the pull box?...Thanks
Old 11-04-05, 09:57 AM
R
If you are protecting this circuit with a 20 amp breaker then you can run 12 gage wire.
Old 11-04-05, 07:15 PM
T
New Member
Thanks...12 from the panel to pull box...10 150 to shed...12 to recpt. and light... right...
Old 11-05-05, 04:22 AM
R
Frankly I would run 10 gage all the way to the shed, and I would not have made a junction where the cable exits the house, but you certainly can.
What type wire are you using? In conduit? GFCI protected?
Old 11-05-05, 08:37 AM
T
New Member
10 gauge stranded in pvc.....I can run 10 from the panel to the juction box...If it wasn't such a long run I would have run 12 gauge...Thanks
