generator info please
Old 11-04-05, 05:37 PM
BIGJIM05
Has anyone used a generator that runs the entire house?
I am looking for the proper setup for a home to be able to have a generator wired into the whole house system that whenever there is a loss of power for more than a minute it takes over and runs the house.
Thanks
Old 11-04-05, 05:47 PM
Speedy Petey's Avatar
How big is the house?
What size is your service?
What electrical appliances do you have?
How much electric heat?
How much A/C?
Do you have nat.gas on site?
You should do a load calculation for your electrical needs to determine how big a genset you will need.
A unit to run the average home will be in the $10k-$12k range installed.
Old 11-04-05, 05:54 PM
BIGJIM05
florida home
we have a florida townhome that has 6 rooms and this is a real problem down here laterly with power and storms.
If I get these numbers together is there anyone to contact to do this for me-just an electrical contractor-or who? Also is there a certain brand to look for.
Thanks for all your advise.
Old 11-04-05, 06:54 PM
Kohler and Genrac are some brands. The installation has to be properly designed and permitted. Need a transfer switch so you do not backfeed the power line.
What are you condidering for a fuel source? Probably not allowed to store enough gasoline or diesel on property. That leaves propane and natural gas. Do either of these survive hurricanes and coastal flooding?
Old 11-05-05, 01:49 PM
BIGJIM05
Generator Info
THANKS SO MUCH! GREAT IDEA. I never thought about using propane or natural gas. I will look up these 2 names and I really think the propane option may work best for me.
This site is the best because of all of you that help others.
IT IS APPRECIATED!!
