3 way switch to hall light
There are at least eight different ways to connect a three way switch we need more info.
Look at the drawings at this site. It may help you.
http://www.selfhelpandmore.com/switc...3way/index.htm
ON THE 3 WAY SWITCH THERE ARE THREE SCREWS ONE IS BLACK CALLED THE COMMON THE OTHER TWO ARE TRAVELERS. THINK OF THE COMMONS ON BOTH SWITCHES AS A SINGLE POLE REGULAR SWITCH, ONE COMMON GETS THE HOT WIRE CONNECTED TO IT AND THE OTHER ONE GETS THE SWITCH LEG GOING TO THE LIGHT. THE TRAVELER CONNECTIONS ARE STRICTLY BETWWEN THE TWO 3 WAY SWITCHES, THIS IS HOW YOU CAN TURN ON AND OFF YOUR LIGHTS WITH BOTH SWITCHES. GOODLUCK AND BE SAFE! SOUNDS CONFUSING, I KNOW!
