Wire temperature rating
Old 11-05-05, 10:18 AM
CRFJOHN
I recently purchaced some new ceiling fixtures that have flourscent bulbs. I see on the fixture that they require wiring that has a temperature rating of 90c and homes built before 1985 may not have proper wiring. Can I determine from the printing on the cable if it is the kind of wire needed for these fixtures?
Old 11-05-05, 10:41 AM
Usually yes. Modern cable and conductors have the temp. rating printed on.
Old 11-05-05, 12:31 PM
TomZ1's Avatar
If it's non-metallic cable (romex) you are looking for "NM-B." The "B" means it's 90-degree C wire.
Old 11-05-05, 02:18 PM
CRFJOHN
Thanks guys! I've got both NM and NMB cables. I spoke to and electrician that I know and also got some advice from him. He told me to keep the existing wires away from the ballast and there will be no problems even with NM cable.
