Flex Connector
Old 11-06-05, 10:19 AM
alt
Flex Connector
Hi,
I managed to cut the wire for my laptop's power supply in half, and need to fix it. It currently looks like this:
240V plug-----------------transformer---------------cut cut-----laptop plug
The cable is a 2 strand one, and apparenlty gives 19.5V DC at 2.15A. I bought one of these:
http://www.maplin.co.uk/module.aspx?...&doy=6m11&QV=P
but on the back it says "AC ONLY". I can't for the life of me see why I shouldn't be able to use it for DC. Can I safely use it?
Old 11-06-05, 11:44 AM
have you tryed radio shack youll find something you can use there for dc . but if you want to know why you cant use that one you can call them its long dist contact there customer support at 0870 4296000, and they would be in a better position to help you out in this regard.
Old 11-06-05, 12:13 PM
johnam's Avatar
Received 3 Votes on 3 Posts
With DC you must maintain polarity (+ & -). As long as you connect the wires exactly as they were when they were cut, you should have no problem.
