Can I hook a regular 120 a/c plug to duct fan?
Old 11-11-05, 03:49 PM
dan383
I am no electrician,
I just bought an inline duct fan and it is meant to be hard wired to a switch. I would like to hook it to a regular wall plug and turn the fan on by plugging it into a receptacle. The fan is only temperary. Is this a stupid thing to do? Any help will be appreciated.
Thanks
Old 11-11-05, 04:14 PM
What kind of duct?
Old 11-11-05, 05:11 PM
dan383
An 8" inline air duct fan to help boost air from my basement to upstairs. The link below is the fan. You may have to copy and paste.
http://www.smarthome.com/3012.html
Old 11-12-05, 05:44 AM
I would use a box,connectors,switch and proper wire for this installation.Cords and plugs in attic or crawl spaces not good practice.
Larry
Old 11-12-05, 07:08 AM
I do not believe that it is _necessarily_ a bad thing to cord and plug connect this fan. The devil is in the details however.
If I follow the link that you posted to the Smarthome site, under 'Details and Specifications' they say the following '...just add the optional #3018 DuctStat Duct Fan Thermostat. The DuctStat requires that the duct fan have a 110V plug end.... ' If you look at the installation instructions, there is a picture of a flexible cord going from the fan and plugging in to the duct thermostat.
IMHO doing this with a short length of cord plugged into a nearby receptacle would be fine, even as a permanent install; using a long length of cord or an extension cord would be problematic since 'temporary' use often becomes permanent.
I would use 'hard service' SO cord of at least 14 ga. and a good quality heavy duty cord cap.
All splices need to be in the electrical box, and where the cord comes out of the electrical box you will need a cable clamp. Make sure that the cable clamp that you buy is rated for flexible cords. Also carefully select a wire-nut sized for the particular wires that you are splicing; flexible cord is somewhat more difficult to work with than regular power cable.
Depending upon your experience level, you may decide to hire an electrician to do a hard wired install, or install a new receptacle at your desired location combined with attaching the power cord to the fan.
-Jon
Old 11-12-05, 08:53 AM
dan383
Thanks all for your help. I will take your advice and probably call someone in the field.
