Circuit breaker #13
Circuit breaker #13
Is there a special tool used to pull a circuit breaker from the middle of group of breakers? I need to replace a 15 amp breaker and it's between others (3 above and 3 below). I unscrewed it after turning off the main swithch, but can't get it out. Thank you for your assistance in advance.
So it's a screw-on breaker? What make/model is the panel/breaker?
Usually, after unscrewing them from the bus, you pull on the center-side (screw-side) and it rotates out, as though hinged on the other side.
