Romex + Great Stuff (ie, expanding foam)
Old 11-12-05, 09:52 AM
I'm planning to use some expanding foam (Great Stuff) to seal some small areas in a wall which separates conditioned and unconditioned space. There is some Romex runnng through a couple of the spaces that I need to seal.
Is it OK to allow the expanding foam to come in contact with and/or cover the Romex?
Old 11-12-05, 06:21 PM
I've used it many times for many years to seal off the holes in top plates with NM cable. Never have had a problem. Never have given it much thought.
Old 11-15-05, 08:24 AM
The manufacturer (Dow Chemical) lists sealing around insulated electrical wires as a recommended usage, so I assume it has been tested on NM cable. I've used it around cables with no ill effects.
http://greatstuff.dow.com/greatstuff/cons/where_use.htm
http://greatstuff.dow.com/greatstuff/cons/faq.htm#faq6
Old 11-15-05, 11:24 AM
Didn't even think about trying their website. I guess they wouldn't show this picture if it wasn't OK:
