need advice to properly site my generator
Old 11-14-05, 08:39 AM
I have a large heavy duty 4 cylinder standby autostart generator that I want to install outside in its own little shed. The place I would like to put it is about 100 feet away from the main panel in my home. Assuming I run the proper gauge wire taking the distance into account is that a bad idea? Will I lose a lot of power because of the distance?
Thanks
Old 11-14-05, 08:50 AM
Not if you "run the proper gauge wire taking the distance into account." But the proper gauge wire taking the distance into account may be pretty expensive.
Old 11-14-05, 09:01 AM
What gauge wire would it take to run 62.5 amps at 240v 100-130 feet? The unit is capable of 15k watts. I am not sure of the surge capability but I am told it can start a motor up to 300% of the running watts.
Old 11-14-05, 09:05 AM
"Will I lose power because of the distance"----- yes, if the selection of the conductor-size is based on the load-current, measured in amps, only.
The power- loss is proportional to the square of the current, i.e., P = IxI XR, with I=current -value in amps, and R = the conductor resistance.
For a load-current = 20 amps, the P-L in the conductors = 20 X 20 X R = 400 X R watts. For a load current = 50 amps, the P-L = 50 X 50 X R = 2500 X R = 2500XR watts.
With a conductor-resistance = .1 Ohm, the P-L = 2500 X .1 =250 watts. You will note P-L increases "exponentially"
You will have to submit an appox load in watts/ kilowatts that you propose supply from the generator for an accurate calculation to determine the required conductor-size.
Good Luck & Learn & Enjoy from the Experience!!!!!!!11
Old 11-14-05, 09:16 AM
PATTBAA I am down the street in Stamford. I grew up in Greenwich and my wife is from P.C. I am not exactly sure what I expect the generator to supply in watts. It has a 15,000 watt normal running load rating. Do I round up some for this? I intend to power my entire house. I don't want to run a separate panel.
Old 11-14-05, 09:26 AM
I advise #2 copper conductors.
The resistance of 1000 ft of #2 = .156 Ohms ,so you can calculate the P-L for 60 amps with this value. Remember---- a 130 "lineal" distance = 130 X 2 for the "circuit-lenth"
of the conductors.
What is the maximum HP-rating of the largest motor that will operate from the generator?
Old 11-14-05, 09:45 AM
I should check my AC compressors but I believe the 1hp pool pump is the largest I would run. I could not see where on the generator to ground the unit. Don't they all require a grounding rod to be located near the unit?
Old 11-14-05, 12:49 PM
Steve:
Please contact me via my EMA------- [email protected]
We can arrange a meeting in order to "engineer" a sucessful project. Please be assured that any & all advise & assistance I provide is "pro bono"--- be glad to help you--
I once was the chief electrician at Stamford Hospital.
Cheers, Al B.
Old 11-14-05, 12:54 PM
Normally, we edit out email addresses in posts, and somebody may yet do so, but I'm not sure why we have this rule. If you want to open yourself up to spam, I don't know why we'd care.
Old 11-14-05, 03:22 PM
Speedy Petey's Avatar
#2cu for 62 amps @ 240v at only 130' ???
Sounds like overkill to me. #4 would be plenty.
