GFI Breaker Change
Old 11-19-05, 08:29 PM
bigpigzeb
GFI Breaker Change
Currently have 15amp two pole GFI breaker in panel that trips often. Want to change to 20 or 30 amp to support current loads. Should this be a problem?
Thanks,
bigpigzeb
Old 11-19-05, 08:34 PM
Speedy Petey's Avatar
Yup. BIG problem!
You cannot simply put in a larger breaker. The breaker must be sized accordingly to the circuit conductors.
Unless ALL the wiring in this circuit is larger than #14 you CANNOT change the breaker for a higher rated one.
Are you sure it is tripping from overcurrent? Could it be a ground fault trip?
What is the load?
