Automatic (light activated) outdoor lamp
I have a light on lamp post in my front yard which is supposed to turn on automatically when it gets dark. There is a light sensor on the lamp pole. I replaced the bulb with a new one and it does not work. Any ideas for a fix?
Have you figured out where the problem is? Is there power to the pole? Is this a screw in sensor that goes directly under the light bulb? If so have you tested it?
Understand that it is not darkness that turns the light on, rather it is light that turns it off. The normal failure mode for a photoelectric cell is that the light burns all the time rather than not at all. Suspect a lack of power to the pole.
