Double pole Gfci Question
Old 11-22-05, 11:31 AM
jericoriver
Can two single pole gfci's be used without causing a problem? Instead of a double pole. (I have the two singles and will have to wait on the double pole)
Old 11-22-05, 11:32 AM
Not on a multi wire circuit. If you have a multi wire circuit then you must use a double pole GFCI breaker to provide GFCI protection at the breaker.
Old 11-22-05, 11:38 AM
jericoriver
I would be using it to power a boat lift. #12 wire and nothing else. If I lock the 2 together(trip handles) would it then be O K or would there be a problem with the G F part.Thanks
Old 11-22-05, 11:51 AM
This will not work if it is a multiwire circuit. It also will not work if it is a 240 volt circuit.
