Switch box question
Old 11-23-05, 07:53 PM
C
Switch box question
I have a light switch located in the garage which is mounted on a wood paneled wall. The box is for a single switch and is screwed into the wall with the little metal tabs (from the front). I would like to add another switch and light and install the switch next to the existing one. I canít seem to find a 2 switch box with the tabs on the top and bottom to mount the box to the wall. (not at the local hardware store or Home Depot) I see single boxes that say they are gangable if I use two of these next to each other will the duplex switch cover plate fix on it? Or is there a better way?
Thanks
Old 11-23-05, 08:38 PM
C
The gangable boxes, when ganged, will provide standard device spacing.
Old 11-23-05, 08:39 PM
flat_broke
RE: Switch box question
What you are looking for is a gangable switchbox. You would get 2 of these and remove one side from each. They then screw together giving you a double switchbox.
Hope this helps. My first post here.
Old 11-24-05, 05:55 AM
R
What you want is an old work box. The boxes that are designed to gang together are generally NOT old work.
Also, before you begin, make sure that you have a power source for this new light. You do not necessarily have one in this switch box.
