Use NM or Armored Cable (BX) in an interior wall?
Old 11-25-05, 10:09 AM
OK. I've done the reading, but I'm still unsure of whether I should use Romex or BX for my wiring project.
I'm installing a ceiling fan where I have access to the ceiling via the attic. I have to run a wire from the attic, inside the wall (more or less along a stud) to an existing wall switch. Since the wall is covered by drywall, I will not be able to secure the wire to the center of the stud, so for all I know the wire could end up laying right on the drywall. If I hang something on a wall in that area later, theoretically I could hit the wire.
I'd prefer to use Romex because it's easier to work with. Am I being overly concerned, or should I suck it up and use the BX?
Thanks in advance.
Old 11-25-05, 10:19 AM
pcboss's Avatar
A couple of things to consider, is NM-B allowed in your area? What type of material are your current boxes made of?
Type AC or MC cable cannot be used with plastic boxes.
NM-B is allowed to be fished inside the wall cavity.
Old 11-25-05, 12:13 PM
NM is allowed in my area and the boxes are made of metal. Can AC or MC be fished as well?
Old 11-25-05, 01:56 PM
MXSparx
yes you can fish those as well.
