Reload this Page >
code? do u need to clamp at box when running wire in condiut?
Old 11-25-05, 11:52 PM
im using the emt type condiut indoors on a enclosed patio.. just wondering if code requires me to buy metal boxes with clamps or some other system to to hold the wire when it enters the knock-out on the box or if the condiut is considered the clamp..
Thanks in advance!
Old 11-26-05, 04:55 AM
You will need to use the proper fittings that mount the conduit to the box, conduit connectors. Usually the box and fitting come as separate pieces. I don't recall seeing boxes with conduit connectors already attached to them.
So, to answer your question. Yes it is required by code.
Old 11-26-05, 04:58 AM
Speedy Petey's Avatar
Weebee, I think you misread the question. He is asking is a wire clamp is needed.
Tim, no. No clamp is needed to secure the conductors at the box the way you would for NM or ac cable.
Old 11-26-05, 05:39 AM
Thats what I get for jumping on the forum without my first cup of coffee! Now that I reread it. It makes perfect sense. And you are right.
Old 11-26-05, 08:38 AM
One for you and one for me.
Old 11-26-05, 09:01 AM
thanks guys for the replies
yah my wording at the end probally confused it a bit.. (does condiut act as a clamp)--
but speedy you did hit it on the head that was my question...
thanks again for the information!
Old 11-26-05, 11:08 AM
If you are exclusively using conduit, it doesn't. If you are running NM into cunduit somewhere, it needs a clamp.
