Flip switch - blow fuse
Old 12-09-05, 11:08 AM
home-re-do
i have a circuit that everytime i flip the switch off i blow a fuse. any suggestions???
Old 12-09-05, 11:18 AM
R
Can you be more specific. What do you mean every time I flip the switch off… What switch?
Old 12-09-05, 12:08 PM
home-re-do
flip switch
i just wired the circuit and when i flip the light switch off i blow a fuse
Old 12-09-05, 12:16 PM
abNORMal's Avatar
You have a short.
Describe the circuit: 3-way or regular
What does it power? Outlet(s), light(s), fan? other?
How did you wire it? To panel? to existing circuit? outlet or switch?
Old 12-09-05, 12:27 PM
R
It would be most unusual to trip the breaker if you turn a light switch OFF. Are you sure it doesn't trip when you turn the switch ON?
If I were to guess, I thinmk it trips when you turn the switch ON, and you have the neutral wire connected to the switch.
Please tell us about this circuit. What does it provide power for, and how did you wire it?
Old 12-09-05, 03:27 PM
Received 237 Votes on 208 Posts
Most common cause of this a switch loop that someone tried to 'fix' because there was a white and black wire connected together. Confirm this by looking at the switch. If there is a black and a white connected to the switch, you have a switch loop.
I will guess that at the fixture there are two black and two whites + the fixture wires. The power feed black needs to connect tothe switch white. The power feed white connects to the fixture white. The switch black connects to the fixture black.
