cooktop
Old 12-12-05, 07:10 AM
cobb1942
Arrow cooktop
How do I wire a new cooktop (4 wire) to a 3 wire circuit? Is it OK to connect the small white wire (neutral) to the green wire and hook up the new unit the same as the old one? Thanks Ed
Old 12-12-05, 07:15 AM
R
You follow the directions provided by the manufacturer.
If this is a cord and plug device then you buy a different cord and plug. if this hard wired then there will be instruction telling you explicitly what to connect and what must be done.
