Doorbell Transformer Buzzing
Old 12-13-05, 07:38 AM
X
I noticed after moving into my home that the doorbell transformer buzzes very loudly. The transformer is in a closet in the basement and I can actually hear it buzzing while I'm upstairs - it is maddening. Is this normal or does this thing need to be replaced? Keep in mind that my doorbell works normally.
Also, I've never seen a doorbell transformer like this. It is attached to the light fixture in the closet. The light fixture looks like a simple, white porcelain, pull chain base and the transformer is attached to it with no wires between them. Is it possible to have a plug-in transformer here? What store would carry something like this?
Thanks - I am going to have many questions on this house since I spotted wires held together with electrical tape (yikes!)
Old 12-13-05, 07:42 AM
5
Your transformer set up is very typical.
As for the buzzing, it can be caused by a stuck button. You could just disconnect the wires at the chime ( mark each wire's location). If the buzzing stops, replace the door buttons. Otherwise, it is just a worn out transformer. This happens. Some laminations become unglued and vibrate, or whatever. Get a new transformer.
Old 12-13-05, 07:45 AM
X
So then it just basically plugs into the fixture like a normal plug? Can I just unplug it to work on it or do I still need to kill the power at the breaker?
Thanks
Old 12-13-05, 07:54 AM
R
I have never seen a doorbell transformer that was plug in. They are hardwired. To replace it you need to turn off power to the circuit.
Old 12-13-05, 10:16 AM
G
Received 2 Votes on 2 Posts
Since the doorbel works normally, the buttons are not stuck. You have what is called a hysteresis hum caused by the "E" and "I" plates vibrating. Only long term cure is to replace the transformer.
Old 12-13-05, 10:35 AM
X
Thanks folks - once I figure out how to separate the transformer from the light fixture - I'll replace it. Home Depot has doorbell transformers for $8 to $13.
Old 12-13-05, 03:35 PM
C
Swapping
If it is a trypical white porcelin or pull string lamp fixture, you remove the 2 screws on the fixture to get into the ceiling box, The trans will have 2 wires going to a black and white wire nut respectively. Remove them. Then you will see the trans mounted with a 1/2" thin nut--remove that, and install the new one in the reverse order. Shut off power first. Good luck!
Old 12-13-05, 04:47 PM
X
Thanks everyone!
