Stange Breaker
Old 12-14-05, 05:46 PM
B
Stange Breaker
In the process of adding a few circuits and getting rid of some that are no longer needed. I moved a 15 amp breaker up a postion and no longer had power to this circuit. Took the same breaker and moved it over to the bottom of the other row and every thing is good again. Do slots go bad? The breaker that came out of the slot was not being used so I dont know if had worked in the past or not.
Old 12-14-05, 05:58 PM
Received 321 Votes on 277 Posts
Slots do go bad. If you look at the bus where it connects you can probably see the damage.
