Boxes on house for outside lights
Can I get opinions for the installation of boxes for electrical service for outside lights? I'm putting on fiber cement board lap siding and I don't know how to position the boxes. Should I use round boxes or square boxes? My builder said to use just a plain square zip box to hold the wires and then screw the light fixture into the fiber cement board lap siding. I don't want to do that. I want to use light fixtures with a round connection to a round box with a gasket. But, I'm not sure as to how far to stick the box out. The lap siding is not yet installed.
I'm concerned about the vertical position of the boxes. Should they be contain on one whole piece of lap siding or should I split them over two pieces of lap siding and then use a thick gasket. Should I wait until the lap siding is installed and then put the box up. I think my neighbor waited until the lap siding was already up and then used a 4" circular saw bit.
Another option is to get a block of the edge board (the one that does vertically at the corners of the house) and put the round box through that so that there is a flat piece to stick the light fixture to.
Thanks
Thanks
I think it is easier to split on a seam between two pieces of siding.
Go to www.aifittings.com and look at the siding boxes that are available.
