Amps
Old 12-18-05, 08:55 AM
chingao81375's Avatar
construction hand
Amps
I have a PVC bender that comes with out a plug. The bender runs on 24 amps. Somebody put a 20 amp plug on it. Does it need a 30 amp plug? Or does it make a difference?
Old 12-18-05, 09:02 AM
Speedy Petey's Avatar
Are you saying it draws 24 amps?
If so then it obviously does need a 30 amp plug.
This doesn't sound like a very convenient tool. Where are you going to find a 125v/30a receptacle on a jobsite, unless you specfically install one.
Old 12-18-05, 09:04 AM
5
Equally important as the AMP rating: what VOLTAGE does your machine require? Each particular shape of plug defines a Volts AND Amps rating. Your macine should have a label plate on it noting the voltage and amps ratings. Get back to us with that info and we can tell you what plug is required.
Old 12-18-05, 06:09 PM
construction hand
i need to know because i work at the warehouse of the construction company i work for. In order to check the tool to see if it working properly. Before i send it to the jobsite. The voltage on the thing says 230volts 24 amps, and 5500 watts. Our warehouse has a 220 volt/30 amp outlet. the bender has a 20 amp plug. I guess i need to replace the plug with a 30 amp.
Old 12-18-05, 06:50 PM
HandyRon's Avatar
