Transformer Wires- got cut.
Old 12-19-05, 11:59 AM
T
While remodeling our bathroom two wires that come for a transformer weree accidently cut. They are in the wall. Can I just reconnect them with twist caps or do they have to be connected in box?
Old 12-19-05, 12:14 PM
R
What kind of a transformer?
Old 12-19-05, 12:29 PM
Received 272 Votes on 235 Posts
If they are the supply(120 volt) wire they must be in a box.
Old 12-19-05, 03:31 PM
T
There not the supply- they are the small single wires that go to the doorbell, etc.
Old 12-19-05, 04:17 PM
R
Just connect them with wirenuts. No need for a box.
Old 12-19-05, 04:57 PM
T
Thanks for the reply. As I understand you, I can connect with twist caps and leave them inside the wall.
Thanks for your help.
I have recently installed several switches that did not have a ground screw on them. I am using a plastic box. The ground from the fixture is connected to other ground wires. Do I need to replace these switches with new switches with grounds?
Old 12-19-05, 10:18 PM
C
For Low Volts,yes
